swapping exhausts????
Old Oct 19, 2010 | 07:49 PM
alansST's Avatar
alansST
ST24
Default swapping exhausts????
Quick Question guys!
Can a exhaust from say Cat back from a T reg ST24 be fitted to a Mk2 mondeo 1.6 16v Zetec (S reg)? only reason i ask is that the ST exits at the rear from the drivers side, an the Zetec exits from passenger side?
Old Oct 20, 2010 | 07:52 AM
The fitting points are the same on all body/engine types, can't say about the fit from cat back though.
Old Oct 21, 2010 | 09:20 PM
alansST's Avatar
alansST
ST24
is the diameter of the exhaust the same on both? can i use the exhaust from the ST on the 1.6 zetec?
if not, where can i get an exhaust from cat back that will exit on the drivers side an not the passenger side?
Old Oct 22, 2010 | 11:05 AM
On the mk1 mondeo the exhaust exit denoted whether the engine was 1.6/1.8 or 2l as tailpipe was on opposite sides so could use the mk1 exhaust possibly, I doubt the ST24 pipe will be the same diameter, places like powerflow dealers can custom make you a exhaust as you want it.
tankybaby66
Feb 6, 2016 02:24 PM
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
