i want to change my 1.6 to a 2.0 help needed
Hi all i was going to wait till the new year to do a 1.6 to 2.0 swap on my 99 escort but my engine has died on me so no better time then now to do it
any help or advise will be great. i know i need to change the sump and all the pumps and the AFM and TB i also belive i need to change the fly wheel and clutch to the 1 off my escort i was also going to buy a fuel regulator as well,
now here is were i get stuck is there anything else i need to change i have read about the ecu but not sure which 1 to go for any help please, and anything else i should be looking out for or changing thanks alcraig
Turbocharging Technician
Do you have an engine set aside? basicaly you need all the bits from a 1.8 escort engine to put onto your 2.0 engine, flywheel, sump, pick up, alternator and water pump set up (all the aux drive stuff needs swapped) inlet manifold, basicaly making a 2 litre escort engine from all the 1.8 bits. You will need a 2 litre air mass meter and ecu, you may struggle to get round the pats imobiliser system though. I wouldnt bother putting on an aftermarket fpr until it is running well and on the road. You will also be looking at a new clutch, timing belt kit, oil and filter change before the engine goes in and posibly new plugs and leads just to be on the safe side. hope this is of assistance.
JoeyBoyden
04-01-2024 02:36 PM
JoeyBoyden
18-08-2015 05:56 PM
