help please!! s2 turbo problem
Old Oct 15, 2010 | 03:30 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
Default help please!! s2 turbo problem
hello peeps,where the oil feed attaches to turbo,that bolt has snapped inside the turbo,now ive tried to use an easyout to remove whats left in there,but the easy out has also snapped and is stuck inside it.
any idea how to remove it?impossible? can that part of the turbo be changed?
or is it easier just to get another turbo?
sorry for all the questions.
im now carless,AGAIN,
cheeRS
Old Oct 15, 2010 | 05:21 PM
Can be done, turbo needs coming off the car, and preferably using a pillar drill or mill if you can drilling out after making a jig to centre drill bit over the easy out.
Any decent machine shop should be able to sort it for you.
Old Oct 15, 2010 | 07:08 PM
rickbartlett
G911 TTA
the easy out that is left in it is about 5 mm wide,it snapped at the bottom
Old Oct 15, 2010 | 08:19 PM
Not a problem, if you use the right people.
Old Oct 15, 2010 | 08:39 PM
rickbartlett
G911 TTA
ok cheers tabetha,im worried that even if they get it out ,that the thread will be knackered.and its quite a specific sort of banjo bolt.
Matt Baxter
Sep 16, 2015 08:30 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
A.t.p
Aug 15, 2015 11:37 AM
druidgetafix
Aug 15, 2015 10:22 AM
