Cracked rotor arm
Old Oct 14, 2010 | 05:45 AM
MARCOSWORTH's Avatar
MARCOSWORTH
Default Cracked rotor arm
What can cause a cracked rotor arm, its cracked on top between the 2 connections.
Car runs ok from cold and when becoming warm hot it runs on 2-3 cylinders now and then
Car's a 4x4 Sierra Cosworth
Old Oct 14, 2010 | 07:33 AM
Usually just age, or impact damage from being forced on ?
Old Oct 14, 2010 | 08:10 AM
MARCOSWORTH
Must be age then.
Is it possible that the car has these symptoms with a cracked rotor arm???
Old Oct 14, 2010 | 05:01 PM
Yes if the crack is over the area between centre and the outer edge contact, as this covers a carbon resistor.
Old Oct 15, 2010 | 04:58 AM
MARCOSWORTH
Yes it is, will change it tomorrow and see what happens
Old Oct 15, 2010 | 09:36 PM
LHD220Turbo's Avatar
LHD220Turbo
if it hasnt been changed for a long time, the plastic has probably become brittle
Old Oct 16, 2010 | 05:15 AM
MARCOSWORTH
Turned out to be the phase sensor as cylinder 1 & 4 were not going properly, changed and all fine
As the rotor arm looked bad i also changed rotor and cap
Old Oct 16, 2010 | 08:32 AM
LHD220Turbo
cheap fix!
Old Oct 17, 2010 | 06:13 AM
MARCOSWORTH
Like always
muzzman1
Sep 30, 2015 08:59 PM
OrionRST200bhp
Sep 29, 2015 08:30 PM
martynhomer01
14
Sep 23, 2015 12:23 AM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
biggiejody
Sep 19, 2015 10:25 AM
