lambda/afr reading Q
Old Oct 12, 2010 | 08:38 PM
sir nose's Avatar
sir nose
Default lambda/afr reading Q
i have a stack afr gauge with the lambda at the top of the downpipe,it reads 0.10 less than a mot gas analyser probe in the tailpipe.
would the afr changed .1 from front of ehaust to rear or is my stack gauge fudged.
Old Oct 13, 2010 | 05:21 AM
oldford's Avatar
oldford
Difficult to say without more accurate figures, especially from the gas analyzer.
A small leak anywhere in the exhaust can cause a change in AFR at the analyzer.
Old Oct 13, 2010 | 11:49 AM
I'd be inclined to trust the mot gauge reading as more accurate, as calibrated every year, and maybe to a higher degree ?.
Old Oct 13, 2010 | 11:52 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Within 0.1 AFR is the same reading really (ie 14.6 instead of 14.7) IMHO thats well within tolerance.
If its 0.1 on the labda scale though (ie .9 instead of 1.0) then thats enough to worry about.
Exhaust blow would tend to make the tailpipe read leaner.
What were the actual values?
Old Oct 13, 2010 | 11:56 AM
chaffe's Avatar
chaffe
Turbocharging Technician
I tend to agree with the above statement, after all your in car gauge is not calibrated unless it is an innovate ls1
Old Oct 13, 2010 | 06:20 PM
sir nose's Avatar
sir nose
it is the lambda reading not afr.
readings are way out cos' it needs mapping i just wanted to check the stack guage was workin and accurate.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Iain Mac
Sep 30, 2015 09:39 PM
20/20 vision
Sep 29, 2015 11:27 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
