1990 xr3i
Old Oct 11, 2010 | 10:09 PM
caprinut's Avatar
caprinut
Default 1990 xr3i
hi im new on here, just on with buying a h reg xr3i, the fella im buying it from says its got a missfire due to needing a new octane adjuster? he showed me it and said it plugs into the wiring harness and then needs to go on a computer to reset the memory of the fuel system, can anyone shed any light on this, having driven nothing but capris for years this is new to me, i went into my local ford dealer and they didnt know what i was talking about, any help much appreciated, thanks
Old Oct 12, 2010 | 12:03 AM
Grandad racer's Avatar
Grandad racer
wow, iv been in to xr3i,s for ten yrs. octane adjuster? thats a new one on me!!
Old Oct 12, 2010 | 12:07 AM
Shings's Avatar
Shings
LOL is all I have to say...
Could be loads of things on a 3i.... none of them particularly expensive to fix but you need to have a methodical approach.
Old Oct 12, 2010 | 06:38 AM
jonny s2's Avatar
jonny s2
efi 3is, could have loadsa probs, have you checked the plugs, or even coil pack??
Old Oct 12, 2010 | 06:49 AM
caprinut's Avatar
caprinut
Default 1990 xr3i
cheers, ill try get a pic of this part up on here, see if anyone recognises it, like i say its just running a bit lumpy and wants to cut out now and again,
Old Oct 12, 2010 | 07:01 AM
chaffe's Avatar
chaffe
Turbocharging Technician
most of the vauxhals had octane plugs, used to put the highest spec one in you could find. Must be an efi xr3i on that age, some did have octane plugs. Not sure this would cause a missfire though, even if it was unpluged. I would be looking at leads and correctly gapped new plugs, as everything else on that particular edis ignition system is pretty bulletproof (assuming it is efi, with edis4 wasted spark) be interesting to see a pic of what he think is to blame though, nothing of this nature would put me off buying the car though.
Old Oct 12, 2010 | 04:44 PM
Octane plug doesn't need the compy to be hooked up, it simply plugs in, ecu says hello and adjusts accordingly.
Octane plug is not going to be the cause of a misfire though.
Old Oct 12, 2010 | 06:54 PM
s6boy1979's Avatar
s6boy1979
The none turbo cvh's always tend to tick over a bit more lumpy compaired to the turbos. My 3i had a really bad miss fire at tick and I have replaced everything I can but still won't over smooth. I have learnt to live with it but if it is really bad start with a service, if that does not sort it check the leads. Get the mixture adjusted, any garage that does mot's can do it for about £20. If it still does it the look at the MAP sensor, idle control valve, crank sensor, find out the last time the belt was changed as the timing could be out slightly, the fuel pressur regulator may need adjusting and a decent garage should be able to do that. Another possible is the fuel pump, mine was running really rough just before the pump died.
Old Oct 12, 2010 | 08:51 PM
caprinut's Avatar
caprinut
Default thanks
thanks for help everyone, ive just bought a nice mk 4 xr3i cab, just gonna strip it for the interior and exhaust, and rs bodykit, everything else will be getting sold off if you need anything, hopefully ill find the cause of the miss on my other 3i and i can rob bits from the cab,
Old Oct 12, 2010 | 09:06 PM
s6boy1979's Avatar
s6boy1979
Is the cab an efi or mfi mate as I need a few bits
Old Oct 12, 2010 | 10:39 PM
caprinut's Avatar
caprinut
Default xr3i cab
im not sure to be honest, im picking it up sunday but ill find out tomorrow for ya
Old Oct 12, 2010 | 10:46 PM
s6boy1979's Avatar
s6boy1979
Cool I need bits of both
Old Oct 13, 2010 | 05:23 AM
chaffe's Avatar
chaffe
Or its probably a worn cvh cam and followers
Old Oct 13, 2010 | 07:11 AM
s6boy1979's Avatar
s6boy1979
Could be the cam are so soft
Old Oct 15, 2010 | 09:20 PM
caprinut's Avatar
caprinut
Default xr3i cab
just to let you know the engine in the cab is mfi
Old Oct 15, 2010 | 10:19 PM
s6boy1979's Avatar
s6boy1979
How much for the tank, pump carrier and pipes mate
wowk
Mar 30, 2021 07:49 PM
Nov 1, 2015 06:53 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
