Ford S-max key programming
Old Oct 11, 2010 | 08:18 PM
katynka's Avatar
katynka
Default Ford S-max key programming
Hi,
Can you please tell me how to program Ford S-max keys (2009).
My children lost them and I would like to buy a new key on e-bay.
I have previously programmed Ford Focus. Is it same?
Thank you
Old Oct 12, 2010 | 07:16 AM
martysmartie's Avatar
martysmartie
If it's a normal key I.E non remote then procedure will probably be similar where you put ECU into "Learn" mode, have you checked the handbook as it normally says in there?
Martin
Old Oct 12, 2010 | 04:34 PM
katynka's Avatar
katynka
Martin
I have checked the manual and it says to check with the dealer.
I have a flip out key with 3 buttons, I am not sure what is I.E key and ECU.
I am worried if I program it, I will not be able to start it (immobiliser will block it).
Thank you Katerina
Old Nov 28, 2012 | 07:44 AM
trever's Avatar
trever
Originally Posted by katynka
Hi,
Thank you
hello mate! did some quick research for you.. i found you this step by step instructions to follow.. hope it can help! cheers!
cheers!
trev
Daisychain
Aug 22, 2015 08:12 PM
borboyous
Aug 22, 2015 11:17 AM
Bailes1992
Aug 16, 2015 07:14 PM
tankybaby66
Aug 9, 2015 07:13 AM
