Sierra Brakes
Old Oct 11, 2010 | 04:50 PM
Anzie's Avatar
Anzie
Default Sierra Brakes
Trying to find out what brakes are on my Sierra, ordered brakes which came wrong anyway but further investigation and can't find brakes to match the old sizes. I had ordered xr4i brakes as I presumed that's what was on it but here's the sizes does anyone know?
Front 260mm x 35mm
Rear 250mm x 25mm
Thanks
Anzie
Old Oct 11, 2010 | 06:20 PM
Neither of those sizes are fitted on any ford at all.
Are your brakes standard ?, what model sierra is it ?.
Sierras range from 240mm X 13mm, 240mm X 24mm, 260mm X 24mm, 278mm X 24mm, 283 X 24mm, on the fronts, to 253mm X 11mm, 273mm X 10mm, 273mm X 20mm on the rear.
Old Oct 11, 2010 | 06:35 PM
Anzie's Avatar
Anzie
Thanks for the reply
My mate is doing the work to it and has maybe measured wrong so is going to re check tomorrow. The diameters seem to be the same as the Xr4i 2.8 brakes so I have a feeling he's just measured wrong for the other sizes. Its a Sapphire Azura with 24v v6 Cosworth in it and obviously doesn't have standard brake system as Azura's have drums.
Old Oct 11, 2010 | 07:24 PM
Azura's have drums, just like 2.8i xr4i then!!
XR 4x4 had rear disc, 253mm, xr4i 2.8i had drums at the rear, and had 260mm x 24mm front, with single pot caliper, can't remember drum size but was markedly wider than std drums.
Old Oct 12, 2010 | 04:37 PM
Anzie's Avatar
Anzie
So it looks like I have front brakes to fit an xr4i 2.8 and rear brakes to fit the xr4x4 2.8?
Old Oct 13, 2010 | 12:10 PM
The xr4x4 also used 260mmX24mm front but slightly different off set on the discs, basically shallower discs closer to the wheel than the 2wd.
If you tell me the height of the discs I can look it up to see what you have 2wd or 4wd.
Old Oct 13, 2010 | 02:57 PM
Anzie's Avatar
Anzie
When you say height isn't that just like the diameter?
Old Oct 13, 2010 | 05:05 PM
NO, height is the height as if you place the disc on a table with the bell part uppermost , then put straight edge across the bell and measure distance to table from ruler.
Old Oct 13, 2010 | 05:33 PM
Anzie's Avatar
Anzie
Ahh right, cheers for that mate!
Old Oct 13, 2010 | 07:13 PM
No probs Anzie glad to help.
Old Oct 14, 2010 | 01:52 PM
Anzie's Avatar
Anzie
My mate has measured them and has 60mm for front and 35mm for rear. Any idea what they are then?
Old Oct 14, 2010 | 04:59 PM
xr4i are 260mm with a 58mm height, xr4x4 are 260mm with a 53mm height, on the front, on the rear 253mm discs with a height of 34mm were used on the xr4x4.
Old Oct 14, 2010 | 05:02 PM
Anzie's Avatar
Anzie
Thanks very much for that, so we have been able to establish the brakes now.
yatta
May 21, 2016 10:31 PM
155lee
Oct 27, 2015 04:55 AM
focus2351
Sep 9, 2015 09:33 PM
cossirob
Sep 3, 2015 09:17 PM
