L8, no fuel pump
Old Oct 10, 2010 | 07:17 PM
FlashRS's Avatar
FlashRS
Default L8, no fuel pump
Hi all,
Rebiuldin my car after the fire, got a another 4x4 engine loom, I have no fuel pump working.
Feeds are all ok to the relay, its not getting its earth trip to make relay work !
When I give the relay a earth it powers the pump fine.
What triggers the ecu to work the pump?
Runnin wasted spark as well, which is working.
Old Oct 10, 2010 | 07:44 PM
studabear's Avatar
studabear
crank or phase sensor normally, but my fuel pump primes as soon as I switch ignition on
Old Oct 10, 2010 | 08:26 PM
The ecu will send a prime signal if it receives a crank signal, and other conditions are met(time, temp mainly), they won't always prime, but if running obviously the cps is ok, so need to check ecu output pin for pump relay earth, as ecu outputs to pump relay as soon as engine starts anyway.
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
tib2220
Sep 14, 2015 12:33 PM
