zetec blacktop engine mounting
Old Oct 7, 2010 | 04:31 PM
leigh-k18's Avatar
leigh-k18
Default zetec blacktop engine mounting
hiya guys and girls not been on here for a while but any way i’m looking at putting a 2.0 blacktop into a fiesta mk5 but I’m a bit unsure which blacktop mounts to go for as there seems to be to different types??
the mounts on a focus for a black top sits in the middle of the cam side with two bolts sticking up and then bolts to a mount on the wing like so..
http://img.photobucket.com/albums/v2...d/DSC00352.jpg
http://t1.gstatic.com/images?q=tbn:A...Levl4uD00rZY4=
But then this is also a blacktop and is mounted at the back i’m guessing the same as how you would fit the sliver top as the mount for that is also on the rear
http://lh3.ggpht.com/_78-fCC5CP3U/Sj...0/DSC02579.JPG
so i’m a bit confused which is the better way, and the way i should look at doing in into my shell? do the st170 engine and frs engine use the same mount as the top pic?
JoeyBoyden
Jan 4, 2024 02:36 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
track.focus'd
Aug 12, 2015 05:53 PM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
