Megasquirt And Efi Help Please
Old 28-09-2010, 06:00 PM
liddon21
liddon21's Avatar
Default Megasquirt And Efi Help Please
Hey all,
I know this has all been covered many times before but there is so many posts and replies im getting a little confused.
Im going from MFI ---> EFi
I have got most of the parts needed except injectors and managmenet. I have decided i think megasquirt is best for cost/performence. I'm Aiming for around 300bhp.
What stuff do i need if i go megasquirt?
ECU ??
Loom ??
Wiring Harness ??
MS ii ???
Would really appriciate the help and advice.
Old 30-09-2010, 09:30 AM
mobb-black
mobb-black's Avatar
You just need a loom and the ECU itself. Most times the ECU will come with a basic loom, and you can wire the loom at the engine end to fit your CVH sensors etc
Best way I found to do it for my zetec was start with a Focus engine loom at one end, and the ECU at the other with its loom. Lay them out on the garage floor and match say 'Crank Position Sensor' wire on the engine loom to 'Crank Position Sensor' wire on the Megasquirt loom. It took a while but it seemed like the easiest way of getting Focus sensor plugs onto a Megasquirt loom.
There are folks out there that will make you a loom up, but when I asked around most places wanted 350 - 400 quid.
Ebay Microsquirt, Trigger Wheels sell them with a loom ready to go, and the Microsquirt is a later evolution of the Megasquirt.
mk1turboestate
02-12-2015 08:31 PM
liamT74
23-09-2015 10:24 PM
davidfordrs
21-09-2015 04:23 AM
RSmark84
13-09-2015 01:29 PM
dms04
11-09-2015 01:57 PM
Quick Reply: Megasquirt And Efi Help Please
