twin port actuator FAST FORD this month ???
Are these any good really, looks like a more elaborate bleed valve set up, didnt really have a great explaination on its use and set up, could the same or similar results be possible by decent mapping instead?? Is this worth the money, I really want to reduce the lag i get low down on my T34 /.48 without going back to a T3, will this set up help?
i know but it just seems like it lags more, or maybe its just that I get a harder push when it does come on boost at 24PSI and Im not used to it then, it is the first time Ive used a bigegr turbo, power wont be any less linear then through the revs? Cheers, food for thought .
borboyous
22-08-2015 11:17 AM
TommysKeeper
13
14-08-2015 08:22 PM
