Wot megasquirt kit do I use
After a few failed attempts of gettin my zetec turbo converted mk5 fiesta runnin due to wiring an the fact no one seems to no a thing about these wiring conversions I'm gonna buy a megasquirt kit but which one do I get unless there is sum1 local to Hertfordshire that will come get this beast running I will pay fuel costs an how much u want for doin it also supply t and biscuits just gettin a bit bored now an losing enthusiasm as no body seems to even have any good advice thanks in advance
ON THE ROAD AGAIN
ms2 v3 is a good choice atm there is now the new ms3 but realy depends what you want it to do
i personally would go with ms2
have a look at exra efi site all the info is on there
tommy
tommy
Turbocharging Technician
i have used ms2 v2.2/v3 for edis a couple of times successfully, unless you are driving coils directly and taking signal straight from vr sensor i would use ms2, and edis, its the most reliable and simplist to set up method. Get yourself wideband lambda to map it though mate
