chatter noise, why is it different on mine?
Old Jul 27, 2010 | 04:38 PM
dearing5's Avatar
dearing5
Default chatter noise, why is it different on mine?
hi guys, the chatter off a ford engine sounds classic but on my c20let engine it doesn't sound the same...im running a t34 .63 and it doesnt make the high pitch DA na na na na lol if you get me??
is it to with air filter tube size/filter/no filter etc
Old Jul 27, 2010 | 05:04 PM
JamesH's Avatar
JamesH
I find a lot depends on boost levels and how quickly (or slowly) you shut the throttle
Many believe the trumpet shape/size has a big effect!
Old Jul 27, 2010 | 05:08 PM
pee vee's Avatar
pee vee
Take the air filter off and listen to it then lol.. Very differnt then!
Old Jul 27, 2010 | 06:15 PM
Toe Knee's Avatar
Toe Knee
As said boost level, size of turbo and what filter u run can all make a difference!!!
Old Jul 27, 2010 | 06:27 PM
dearing5's Avatar
dearing5
the turbo is at 11psi and its a .63 turbine 0.50 A/R t34...what you boys run?
i ran a green filter averagre size and now a bigger filter....it has2 90deg bends up and over the chassis leg then into a little straight....the pipe is 3".
i have the AFM there as well but considering moving this so i can run it with no filter etc or some kind of mesh over the tubo inlet.
pee vee - your vid doesn't work
Old Jul 28, 2010 | 10:36 AM
dearing5's Avatar
dearing5
Old Jul 28, 2010 | 11:08 AM
JamesH's Avatar
JamesH
I was running 2bar boost on a T34 but on a Cossie engine
Old Jul 28, 2010 | 03:09 PM
dearing5's Avatar
dearing5
would my afm make it sound different? maybe i could put it the other side of the turbo...i have seen this before.
Old Jul 28, 2010 | 04:36 PM
JamesH's Avatar
JamesH
I would not put it the other side of the turbo I've never seen this
Compressor inlet side, it would possibly see from around -10kPa to 10kPa, compressor out it would see anything upto 250kPa (2.5bar) depending on what boost you're running. Also they are very sensitive things and MAF linearisation etc is not to be messed with!
Old Jul 28, 2010 | 05:21 PM
dearing5's Avatar
dearing5
this is what i thought! a guy on another forum put his on the pressure side...and he said its faultless but i disagree. the wires are very thin that read the air so yeah surely 25psi would wreck it?
i'll try taking the filter off or more boost haha.
mine sounds the same as this
http://www.youtube.com/watch?v=cPZZvd55hxg
and this is what i want??
http://www.youtube.com/watch?v=6J-mS...eature=related
Old Jul 29, 2010 | 08:27 AM
Any difference in the inlet is going to affect if from one car to another noise wise I would have thought.
Old Jul 29, 2010 | 08:45 AM
Chopshop85's Avatar
Chopshop85
^In those videos i think the fiesta sound great.
Seen the video of that escort before and I hate that sound. Really high pitched, it just sounds pathetic.
Old Jul 29, 2010 | 09:10 AM
dearing5's Avatar
dearing5
yeah i guess so....why are they different though?
Old Jul 29, 2010 | 09:17 AM
Kverna's Avatar
Kverna
Virgin-popper
http://www.youtube.com/watch?v=zRPE3tDhlO4
http://www.youtube.com/watch?v=dIRUYvHBGLY
http://www.youtube.com/watch?v=LNawymsX3xA
http://www.youtube.com/watch?v=ULJJhDwhy2k
Gr.a cosworth, 2.0bar+ with 34mm restrictor on a turbonetics turbo
Rod-Tarry
75
Oct 13, 2015 04:44 PM
gingeRS
17
Oct 2, 2015 09:42 AM
Botts
Sep 22, 2015 02:04 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
rsturbo27
Sep 5, 2015 05:08 PM
