knocking from front when steering -Escort
Old Jul 20, 2010 | 07:36 AM
Rema-d's Avatar
Rema-d
Default knocking from front when steering -Escort
Getting a knocking from the front somewhere, not sure what it could be,
its over big bumps sometimes and steering sometimes, but also when driving say 30mph and give it a quick sharp turn to the right, i get the knocking noise. so when driving along if i keep doing quick yanks of the steering wheel to the right, i get the noise each time i turn the car.
Any ideas what thos could be? driving me mad. Did try jacking up the drivers side front and yanking on the droplink but it seemed pretty solid
any ideas much appreciated
Old Jul 20, 2010 | 05:50 PM
Rema-d's Avatar
Rema-d
to add, get the knocking when i push down on drivers of bonnet/suspension strut.
get the knocking noise if i bounce it up and down then
any ideas?
Old Jul 21, 2010 | 09:51 AM
invictus's Avatar
invictus
sounds like your passenger side suspension coil is snapped
Old Jul 21, 2010 | 01:06 PM
Rema-d's Avatar
Rema-d
2nd post, and a useful comment. cheers bud, and welcome
will have a look tonight
Old Jul 21, 2010 | 02:08 PM
Fordmad!'s Avatar
Fordmad!
Could be coil or the bushes on the arm. If its a mk6 Escort that is a commen problem. Maybe your CV Joint but I doubt it.
Old Jul 21, 2010 | 02:17 PM
The only real way to check the drop links is to unbolt one end, if the wheels are at different heights there will be tension on the drop links, so you'd be unlikely to feel/detect play.
Other things to check are the tca joint, and the wheel bearing, a dud/broken spring will not cuase a clonk but can cause the inside of the tyre to be wiped out.
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
hopper350
Sep 4, 2015 12:53 AM
StephTell
Sep 2, 2015 06:31 PM
C2 MAK
Aug 20, 2015 09:46 PM
