Break disk replacement.
Old Jul 18, 2010 | 10:44 PM
figjamuk's Avatar
figjamuk
Default Break disk replacement.
Hey guys, im new to the forum and im sorry to jump in straight away with a dumb question.
I need to replace the disks on my Focus MK1 1.8 Zetec, I have had a quick Google but I am unable to find anything remotely useful.
Ive had the card up on Axle stands and had a look but im unsure of how to remove the disks, from what I can tell is I should remove the calliper and then tap the disk loose. Is this correct and if not do I need to remove the locking nut on the end of the drive shaft to allow the disk to come loose?
Thanks in advance
Old Jul 18, 2010 | 11:06 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
you got it in one mate. remove the 2 bolts holding the caliper on and the disks will tap off.dont undo the drive shaft nuts tho. i would recamend changing the pads as well as the disks
Old Jul 19, 2010 | 09:43 AM
figjamuk's Avatar
figjamuk
Thanks buddy, guess what im doing when I get home from work
I will see how the current pads cope as they are pretty new and have only covered around 1500 miles, ill give em a try and if no good ill chuck em.
Thanks again
Old Jul 19, 2010 | 09:58 PM
figjamuk's Avatar
figjamuk
All done and working, thx for the help
chowfornow
14
Jan 5, 2019 09:01 PM
Sp3no
Sep 27, 2015 07:23 PM
