mondeo turbo engine conversion
Old Jul 18, 2010 | 02:02 PM
decustomengineering's Avatar
decustomengineering
Default mondeo turbo engine conversion
i have a mk1 mondeo 2.5 v6 and was wondering how easy it would be to put in the volvo 2.5 5 cylinder turbo engine into my car.
plus what parts will i need apart from engine
cheers
Old Jul 19, 2010 | 12:28 PM
mobb-black's Avatar
mobb-black
Nothing from volvo will fit easily in that generation of mondeo. I would look at the zetec turbo route if your after daft power.
Old Jul 19, 2010 | 12:48 PM
boy-racer-1's Avatar
boy-racer-1
well wont be that easy but if you can weld and do fabrication work then shouldnt be too much of a struggle for you, if its your 1st time attempting something like this then its going to cost you alot and be alot of messing about at a struggle, i think there would be two ways in which you can do it
1. fit the volvo engine and gearbox, which involves costom mounts and more then likely modifying the driveshafts/hubs, and all the usuals such as engine wireing loom mounting intercoolers, exhaust mods, maybe different feul setup etc
2. fit just the engine, costom engine mounts, i think the gearbox bellhousing will need to be modified no doubt to bolt on, shouldnt be too much trouble i would think if you can ally weld? modified flywheel and no doubt ive missed out other bits that will need doing
Old Jul 19, 2010 | 01:01 PM
Fiddy's Avatar
Fiddy
anything is possible, depends how much you want to spend, and how good you are with a set of tools. will involve a lot of fabrication i would have thought.
You never thought about supercharging the V6 thats in it ?. or using something that wouldnt be as much chew, like a MK1 Focus RS engine ?
Old Jul 19, 2010 | 01:29 PM
jammerrs's Avatar
jammerrs
i agree with fiddy, st220 engine with a supercharger or zetec turbo/supercharged
JoeyBoyden
Jan 4, 2024 02:36 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
