wiring a fuel pump realy?
Old Jul 3, 2010 | 08:26 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
Default wiring a fuel pump realy?
how do you wire up a fuel pump realy (esc turbo 1)
i take it
1 pin is pos
1 pin is switched from ign
1 pin is output to pump
and other is grnd??
if so dose any1 know what pin dose what?
tommy
Old Jul 4, 2010 | 06:06 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
bump
Old Jul 4, 2010 | 06:58 PM
85 is earth
86 is live(trigger, ignition switched live)
87 is OUTPUT to the pump
30 is the supply for the relay, ie from battery etc through fuse
If the relay has a 87a just ignore this terminal, it's just a changeover relay, but will work perfect for what you need.
Old Jul 4, 2010 | 09:43 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
Originally Posted by tabetha
85 is earth
Nice one mate thats eg what im looking for
thanks
tommy
Old Jul 5, 2010 | 04:27 PM
No probs tommy, only a pm away if needed.
cossie09
Sep 14, 2015 04:21 PM
jonjg
Sep 1, 2015 03:46 PM
YODI
Aug 30, 2015 01:12 PM
ekjim
Aug 27, 2015 05:20 PM
kosienutter
31
Aug 22, 2015 09:55 AM
