3 Door Cossie not starting
Old Jun 26, 2010 | 08:09 PM
jason_nike's Avatar
jason_nike
Default 3 Door Cossie not starting
Had the cossie out today, nice run upto Enhanced Performance (thanks for good day guys) for their rolling road day.
Drove and run fine, got home, turned engine off and went indoors.
Came out a bit later, went to put car in garage, wont start.
Turns over, but wont seem to fire up.
Fuel pump doesnt seem to work, tested for power, none.
Tested for spark (plug one out, put in spare plug, then onto rocker) doesnt seem to spark.
I am not the best mechanic around so after advice please if anyone can help
Thanks in advance.
Old Jun 26, 2010 | 10:48 PM
boost mad's Avatar
boost mad
if your not getting spark or fuel then i would check you phase and CPS sensors.
does it prime when you switch on ignition ?
Old Jun 27, 2010 | 10:53 AM
Depending on how hot it is it may not prime anyway, I would check the CPS, crank position sensor, bottom edge of front pulley about the 7 o'clock position, do a wiggle on the connector for it also.
Old Jun 27, 2010 | 08:37 PM
jason_nike's Avatar
jason_nike
Thanks to all, checked evrything, no change so far.
Bloody car!!!!
Old Jun 27, 2010 | 10:38 PM
martysmartie's Avatar
martysmartie
As said defo sounds CPS related, do the wiggle test and check connector and also make sure one of the four lugs on the crank pulley has not broken off.
Martin
Old Jun 28, 2010 | 05:30 PM
jason_nike's Avatar
jason_nike
Tried car today after leaving for a day. hooray it starts again
thanks for all info
Old Jun 28, 2010 | 06:08 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
Its just a ford thing lol
saph in dorset
Aug 14, 2015 10:10 AM
track.focus'd
Aug 12, 2015 05:53 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
Old ford
Jul 31, 2015 06:50 AM
