Cant crank over engine manually after rebuill
Old Jun 26, 2010 | 07:32 PM
brooksy898's Avatar
brooksy898
Question Cant crank over engine manually after rebuill
hello to every one.
Ive just put my cylinder head back on after taking it off to replace the head gasket and got the head skimmed at the same time (138.50). i wanted to find out how much clearence ive got between my valves and pistons but when it came to cranking it over manully the enigine wouldnt move it was solid. what could be the cause of this and what other ways are there to check the clearence between the valves and pistons.
Old Jun 26, 2010 | 07:40 PM
wayne dowling's Avatar
wayne dowling
does it turn over at all if it turns then locks up check the timeings set right
Old Jun 26, 2010 | 08:43 PM
brooksy898's Avatar
brooksy898
no it doenst turn over by hand at all. The engine is all timed up correctly. it turns over easy when the head is off.
Old Jun 26, 2010 | 09:15 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
timing 180 out >?
Alvyn's Avatar
Alvyn
if it's timed up correctly then it can only be 1 or 2 things the valves are hitting the pistons or the cams caps are too tight/seized!
Cossie???
Old Jun 26, 2010 | 09:20 PM
AaronsKa's Avatar
AaronsKa
Turns over by hand with the head off because of no compression. Check your timing again.
Old Jun 26, 2010 | 09:23 PM
OldDan's Avatar
OldDan
All well and good checking timing but as he says he's trying to check valve/piston clearance. Have you had too much taken off the head?
Also have you tried to turn it over without the plugs in?
Old Jun 26, 2010 | 09:44 PM
forevaford's Avatar
forevaford
take belt off then turn each shaft indevidually, see which ones stiff. probly a cam. are cam caps on right and in the right order?
cossie???
Old Jun 26, 2010 | 10:13 PM
Mark Barber's Avatar
Mark Barber
call me i can probably help sort this problem
Old Jun 27, 2010 | 07:37 AM
borderfox's Avatar
borderfox
Hardly mixed up cam caps by any chance.
Old Jun 27, 2010 | 10:13 AM
brooksy898's Avatar
brooksy898
yes it is a cossie engine, 2wd sapphire.
all the timing is correct and all the cam caps are in the correct place and tightened correctly. the head thickness is 138.50 but i got told thats ok.
Old Jun 27, 2010 | 11:10 AM
brooksy898's Avatar
brooksy898
can any send me a few pictures of what the cam setting should look like. i know ive set it right but just to be on the safe side.
another thing does the camshaft sprockets go on the cam one way.
Old Jun 27, 2010 | 11:38 AM
paul16v's Avatar
paul16v
Monte 087
On the std pulleys the 2 pointers should point directly at each other.
Old Jun 27, 2010 | 11:44 AM
COLEYST200's Avatar
COLEYST200
the V in the bottum pully is not TDC its the lug that comes after it that is TDC only saying as iv nown lads to set the timing up of the V
Old Jun 27, 2010 | 11:47 AM
COLEYST200's Avatar
COLEYST200
All so pull all the plugs out as this will help you turn the motor over . But Dont hit the key till the motor turns over by hand at least 2 or 3 times
Old Jun 27, 2010 | 11:49 AM
paul16v's Avatar
paul16v
Monte 087
Here is an old thread ive found bud,
https://passionford.com/forum/techni...am-timing.html
Old Jun 27, 2010 | 12:23 PM
brooksy898's Avatar
brooksy898
everything is lined up properly to the tdc marks. il give it another go again later.
Old Jun 27, 2010 | 05:34 PM
brooksy898's Avatar
brooksy898
it works know. i think it was me being weak trying to turn it over . but thank you to all for the help.
JoeyBoyden
14
Aug 15, 2015 09:51 PM
Zoggon
Aug 10, 2015 10:39 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
lockie
Jul 31, 2015 10:03 PM
Old ford
Jul 31, 2015 06:50 AM
