turbos
Old Mar 20, 2004 | 12:17 PM
Default turbos
i am after a new turbo as mine seems to be on its last legs. im after something HUGE to slay all subaru drivers. im willing to spend between
£1000 upto £1800 pound on a big daddy of a turbo. any help will be good
cheeRS
Old Mar 20, 2004 | 12:44 PM
swerv's Avatar
swerv
you havnt really said about what spec you have??
Old Mar 20, 2004 | 05:21 PM
exhaust,viper air filter,green inj,chipped,3bar map,rs500 intercooler,adj boost,and a bigger turbo
Old Mar 20, 2004 | 05:23 PM
Toe Knee's Avatar
Toe Knee
What sort of compression ratio??? engine work ie head etc?! low/comp or standard?!?!?! WIth greens you can get upto about 380 with a t34 mate.
Old Mar 20, 2004 | 05:56 PM
PJay's Avatar
PJay
Compression ratio and headwork/cams are critical when you decide to go over 400 bhp
Old Mar 21, 2004 | 09:17 AM
as far as i know its had no head work its just standerd with those parts on it. cheeRS
Old Mar 21, 2004 | 09:38 AM
Toe Knee's Avatar
Toe Knee
If your sticking with the spec you listed mate then theres no point going for bigger than a t34
Old Mar 21, 2004 | 11:18 AM
PJay's Avatar
PJay
You could go with a t4 for 400bhp but this is pretty much the limit with standard head/cams
Old Mar 22, 2004 | 05:24 PM
ok thanks for the help. how much would i be looking at for a t4. if any one knows and where the best place would be to get one thanks
Old Mar 22, 2004 | 07:52 PM
Mike Gurney's Avatar
Mike Gurney
get a t34 on it - its a good compromise between power and lag
Old Mar 23, 2004 | 06:35 AM
i will think about it
Old Mar 23, 2004 | 05:55 PM
What about the t38 which seems to have appeared lately. Apparently its got more power for not much more lag.
Old Mar 23, 2004 | 06:37 PM
Theres a T4 on ebay £600
Old Mar 24, 2004 | 03:42 PM
where can i get some info on this t38 turbo
Old Mar 24, 2004 | 06:35 PM
swerv's Avatar
swerv
turbo technics , or do a search on this website as there has been some discussion about it.
Old Mar 25, 2004 | 05:22 PM
thanks
Old Mar 25, 2004 | 05:34 PM
PJay's Avatar
PJay
T38 is a good turbo but the head has to be ported to combat surge issues
Old Mar 25, 2004 | 08:38 PM
Fast Guy's Avatar
Fast Guy
http://www.turbodynamics.co.uk/
‘The Ultimate Turbo for Cosworths’
Manufactured to fit 2WD & 4WD Sierra Cosworths, RS500 & Escort Cosworths.
Hybrid turbocharger – Part No. MD240
All units are hand built and blueprinted to exacting tolerance for each customers needs.
Specification
1. 48 trim, 93865S specification TO4E 76mm high flow compressor wheel with 53mm inducer diameter.
2. 0.70 A/R compressor housing with 3 or 4-inch diameter inlet & 2.5 inch compressor discharge for maximum air
flow capability.
3. Left hand threat shaft with GT28 series 76 trim ‘low inertia’ Inconel turbine wheel, fitted with a racing ‘Staggered
Gap’ total seal ring to stop oil seepage caused by large bore or low backpressure exhaust systems.
4. Modified bearing housing fitted with angular contact twin roller bearing cartridge for maximum thrust load
capability and fastest ‘spool time’.
5. Specially modified turbine housing, 0.61 A/R with ported & polished inlet throat.
6. Optional uprated actuators (any pressure) fitted to strengthened welded on aluminium actuator bracket.
7. Compact GT28 bearing housing assembly for optimum water and oil cooling efficiency.
Note. Requires modified oil feed pipe and oil drainpipe. Oil feed adaptor fitting and oil return flange
supplied with turbo.
What you can expect for your money
1. Boost pressure starts @ 1,800 - 2,000 R.P.M.
2. Full boost (limited) 2.1 BAR @ 2,800 R.P.M.
3. No drop in power @ 6,700 R.P.M.
4. Increase in torque and horsepower over the TB34 unit through the entire rev range.
5. A conservative 450 BHP potential.
Re-mapping is a must with this unit, as the standard ignition map will not keep up with the fast spool up time of this
unit. Performance will vary depending on engine specification such as camshafts etc.
Any use?
Old Mar 26, 2004 | 06:39 AM
yer should be thanks
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
