Fuel pump relay?? the pink 1
Old Jun 5, 2010 | 09:18 PM
mill5y's Avatar
mill5y
Default Fuel pump relay?? the pink 1
I was driving along when I backed off the throttle and knocked the pink relay with my foot. The car just died. I wiggled it and it started for a couple of seconds then stopped. It's a mk4 xr3i cabriolet. Are all the relays the same across the escort range or do I need a xr3i, can I use a turbo, or mk5 etc..... Its the pink relay in drivers footwell that is the fuel pump relay isn't it?
Cheers Al
Old Jun 6, 2010 | 07:42 PM
Not 100% by any means but pretty sure any k jet(MFI) engined one will/does have the same relay.
A lot of trouble from these relays, a lot of people simply run a live direct from ignition to a std spst relay, through a fuel cut off swithc as fitted to efi models(to shut the fuel off in the even of an accident) and have no further trouble.
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
15
Oct 7, 2015 03:43 PM
tib2220
Sep 14, 2015 12:33 PM
