Escort cosworth green fan relay
Hi guys....im new on here so please be gentle I wonder if you can help me?
I need a new or second hand cooling fan relay (the green one behind the battery) on my big turbo escort cosworth. The part number is 93GG8C616AB.I have been to ford main dealer and they told me it is no longer available??? Have tried lots of breakers but no luck there either Please can anyone help??
If you look at the base of the relay, ie so it is upside down you should see numbers next to each terminal of the relay, it is these that I need, as I suspect it is a std item fitted to lots of other stuff, that I can then match up for you.
pic of fan relay with numbers
http://s882.photobucket.com/albums/ac26/cozzy_chick/
Hi Tabetha
Please see above link to picture of fan relay, you can see the numbers clearly on that. Hope it helps, look forward to your reply.
Thanks
Hi Tabetha
Thanks
I can't quite make all the numbers out clear enough, but the numbers I could decipher it looks a 2 stage relay.
I have sent you my email, send me a decent piccie, as I can't enlarge that one, I'm crap on the compy!!
The relay is almost certainly made by bosch, if not it will be a siemens one under license, so may still be able to get one from them, may look different but do the same job.
jessie_rs
11
03-06-2019 04:57 PM
