main shaft bearing removal ?
Heat your oven to 150 degrees centigrade, put the casing in for 30 minutes. Take out of the oven and then using a slide hammer knock out. Don't use a bar under the casing underneath the bearing as it is very thin, you risk breaking the casing!
got it out in the end cut through it with a dremel and knocked it out
Si B
12-09-2015 06:49 AM
grishenko45
09-09-2015 12:58 PM
