1.8 xr2i clutch
Old May 4, 2010 | 07:29 PM
simps's Avatar
simps
Default 1.8 xr2i clutch
my clutch has started slipping so im going to change it this weekend and wondered if any1 could throw me a quick guide together to do it?
my mate who is helping me has only done cable clutches before never a hydraulic.
im buying a clutch kit and a slave cylinder. so all will be changed at once.
Old May 7, 2010 | 04:14 PM
JonathanJ's Avatar
JonathanJ
Never thought this had a hydraulic clutch , all MK 3s had cable I thought ?
Old May 7, 2010 | 04:29 PM
simps's Avatar
simps
i might be wrong as i have since been informed of this.
im running it in a mk5 fiesta and just assumed it was hydraulic but been informed by my local motor factors im wrong too.
although i am using an ib5 gearbox if this makes any difference?
Old May 7, 2010 | 04:41 PM
JonathanJ's Avatar
JonathanJ
easiest way is to have a look at the top of the box and see if a cable is present , you might have a hydraulic clutch in it , but you said 1.8 xr2i , so I guess it is a mix match then
Old May 8, 2010 | 06:19 AM
simps's Avatar
simps
ahh sorry bud.
is a hydraulic clutch compatible with the engine then will have a look when the weather gets a bit better.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
