Bloody fuel relay
Bloody fuel relay
Can someone on here PLEASE help me to put this issue to bed ! i have the usual s1 fuel relay fault and am looking to replace with new or at least working second hand part , before we go into saab stuff or contacting ford or even volkswagen please let me say that all of these avenues are dead .not to mention the chap who apperantly got one from Unipart( they dont do fuel relays!!) I know i sound a bit pissy but when your toy wont play when the weather says all is well what do you do!!!!! Its doin me nut in people .surely someone knows something without the Need to covert to efi and run the pink relay! i run mfi and 1600 and im proud of it ! if someone has a constructive and informative way of rectifying or replacing this unit id eternally greatful, part number v85ab9p704ba THANKS TO ALL pain in the RS
You're not the first with this problem, the system uses a "fuel" relay, or to give it it's proper name a timer, this is used only to prime the system prior to starting, when the pump runs continuously, the excess pressure being diverted back to the tank.
The cure ?, rewire the pump through a std relay from position 2 ignition, but through a fuel cut out switch, such as found on efi cars mondeo etc etc for safety.
Net result 100% end of problems and in safety, why people don't do it I don't know the pumps are not bothered a bout a prime, they will do this in a sec or so when turned to pos 2 anyway, total cost should be about 1 hours work and £3 for a relay!!
First thing is any relay can be used, ie a boggo std yellow relay as found under all ford bonnets.
This will have numbers 30, 85, 86, 87 marked on it.
Connect as follows,
30 supply from a permanent live/battery through fuse.
85 earth, only needs a very thin wire
86 live from position 2 of ignition, again only needs a thin wire
87 is output(live) to pump live terminal.
So terminals 30 and 87 become connected once the ignition is turned on, so need to be heavy enough to handle around 10 amps, 32/020 thinwall is ideal, or 28/030, somewhere along the 87 wire you need to insert a mondeo type fuel cut out, solidly mounted to the bodywork, as these need the "shock" of an accident to trip them into cutting the supply, job done.
Connect as follows,
