RST manifold damaged - can they be fixed?
Old Apr 28, 2010 | 01:38 PM
mobb-black's Avatar
mobb-black
Default RST manifold damaged - can they be fixed?
Sorry to sound niaive, I've been given a cracked Escort RS Turbo exhaust manifold. Can they be fixed in any way??
Old Apr 28, 2010 | 01:45 PM
Yes can be fixed no problem, that's no gaurantee it won't break again though, the sheer heat of turbo cars tends to crack the manifolds, but a lot last years after cracking, cossie ones are always cracking.
Old Apr 28, 2010 | 02:06 PM
mobb-black's Avatar
mobb-black
how do you go about getting it fixed?
Old Apr 28, 2010 | 05:56 PM
MarkN's Avatar
MarkN
I bought a new one off ebay for about a tenner as I recall. Better than welding up an old one which will always have a weakness.
Old Apr 28, 2010 | 07:10 PM
saph_Al's Avatar
saph_Al
I agree with MarkN easier to buy a new one but if you were to weld it then the way to do it would be to mig it with a mild steel wire then when youve finished bury it in sand and leave it to cool down naturally , this helps to prevent it cracking as is common with welding cast metals . Cheers Ally
Old Apr 28, 2010 | 07:23 PM
botters's Avatar
botters
competant bodger
put it in your oven at about 250 degrees for half hour, weld it quickly then bung it back in the oven and cool it down about 10 degrees every 5 minutes or so till cool this should prevent it from cracking as cast has a tendancy to do after being welded
Old Apr 28, 2010 | 08:32 PM
mobb-black's Avatar
mobb-black
ok. Its for a zetec turbo build, so thought i'd pinch it off a mate as he's bought an expensive one. Should I just put my hand in my pocket and fork out for a decent one?
Old Apr 29, 2010 | 04:03 PM
Lumiweld it, only need a decent blowtorch, plus the lumiweld rods.
A.t.p
Oct 23, 2015 07:54 PM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
caprixpack
Sep 25, 2015 07:53 PM
