Escort van starting problems
Old Apr 27, 2010 | 07:02 PM
sikora's Avatar
sikora
Default Escort van starting problems
Having problems with my Escort van again (1999 1.8 Endura DE non turbo)
Some mornings it just wont start. Heater plugs come on, stereo works etc, but absolutely nothing happens when i turn the key.
I've changed the starter motor and checked all connections to and from the alternator, battery etc. The battery is 2 months old too
Wierdly it'll start later on in the day and has ran fine all weekend. Its as if it doesn't like going to work in the morning!
Any suggestions?
Old Apr 27, 2010 | 07:08 PM
saph_Al's Avatar
saph_Al
factory imobilizer ? Have u a different key for it to try ?
Old Apr 27, 2010 | 07:10 PM
sikora's Avatar
sikora
Thought that but the immobiliser light goes out as normal. Only have the 1 key too
Old Apr 27, 2010 | 07:21 PM
saph_Al's Avatar
saph_Al
Will it bump start ? Have you checked the switched feed to the starter goes live when the key is turned ?
Cheers Ally
Old Apr 27, 2010 | 07:35 PM
sikora's Avatar
sikora
Cheers Ally
Everytime i come to do the above it starts, as when it plays up i have to quickly find a lift to work. Just been out now and it started first time.
Was thinking about the ignition switch as the likely cause. Theres not an awful lot of electrics on the van for it to be something overly complicated
Old Apr 27, 2010 | 08:31 PM
saph_Al's Avatar
saph_Al
yeah does smack a bit of it being ig switch , easy enough to replace and rule it out , i have a new ford ign switch that iv'e acquired over the years i'll send it to you if its of any use , not a clue what it's off though it's from a tibby , dunno if it's any different with bein for a derv
Old Apr 27, 2010 | 08:49 PM
vinnyvangough's Avatar
vinnyvangough
My brothers van has been doing this.
He told me it was the ignition coil fuse that was dirty or something and it works fine now
Old Apr 27, 2010 | 08:57 PM
saph_Al's Avatar
saph_Al
It's a Derv so won't apply to this , Cheers Ally
Old Apr 27, 2010 | 10:15 PM
sikora's Avatar
sikora
Cheers for the offer dude, just got one off ebay for Ł3 though
Old Apr 28, 2010 | 01:59 PM
Seen it before, last year in fact this van had a new alt/starter/battery, but would do nothing or clunk like a flat battery even though it wasn't.
I found the problem on this one to be a high resistance on the solenoid feed wire, specifically the terminal on the end that bolts to the solenoid, I cut this off and resoldered another one(gold plated) on, it then started when covered in snow after being left weeks and weeks, the oe crimp is crap on the ford terminal, the solenoid draws momentarily 10 amps when in engagement.
Might be worth a look.
Old Apr 5, 2012 | 01:07 PM
jakerobert's Avatar
jakerobert
Going through it my self got a mk 6 van 55 1.8 d new starter battery ect ect starts some times then the red light flashes by the clock and wont fire up until you jump it with another car strange just cant work it out.
Old Apr 6, 2012 | 08:56 PM
cabriolet's Avatar
cabriolet
fella look at the loom that runs above the radiator to the pump they chafe through on the top of the radiator and cause this
Old Apr 7, 2012 | 06:18 PM
jakerobert's Avatar
jakerobert
Thank you il take a look at them wires along the top of the rad ran ok yesterday..... Then today got to argos wouldent start jumped it and started first time strange turns and turns but wont fire until you connect it to another car????????
Old Apr 12, 2012 | 08:22 PM
jakerobert's Avatar
jakerobert
looked at them wires all looks well cant seem to see the anti tamper bolts to take the cover off the diesel pump any ideas?????????
Vincereese
Jun 1, 2023 09:14 AM
Vincereese
Aug 16, 2015 06:38 PM
druidgetafix
Aug 15, 2015 10:22 AM
vdubo7
Aug 2, 2015 08:17 PM
