Rst not starting
Old Apr 26, 2010 | 04:40 PM
MARKSCOSSIE's Avatar
MARKSCOSSIE
COSSIE FAN
Default Rst not starting
Hi my escort rs turbo engine is not sparking when i turn the key..I changed the ecu, fuelling ecu, spark plugs and still no kick..My battery is fully charged and when i turn the key the engine turns but no spark to start it..Your help here will be appreciated..
Old Apr 26, 2010 | 06:07 PM
dangerousbrian's Avatar
dangerousbrian
you tried the coil or the leads?
Old Apr 26, 2010 | 06:19 PM
RSmark84's Avatar
RSmark84
mine doesn't start either and having same problem you mentioned.
do you hear a 'prime' noise from the rear off your car, if so your pump is working, all i get is a click, never heard that before, but i dont get a spark at my plugs either.
check to see if you have a spark at the HT lead from the coil. if so your coil is fine.
no spark at the plugs could mean your dizzy needs replacing.
Old May 5, 2010 | 03:29 PM
MARKSCOSSIE
COSSIE FAN
Hi guys,
I have a spark at the dizzy but still wont start..its turning and seems its goin to start but just wont spark..When i turn the key the dash lights light up and when i turn it fully it seems its goin to start but nothing..When i do it again the dash lights up again but no turn this time..Repeated this again and i get a turn but no spark..What else could it be..
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
stevierob
Sep 7, 2015 07:09 PM
