steering wheel removal
Old Apr 20, 2010 | 11:49 AM
polly's Avatar
polly
Question steering wheel removal
hi there could anyone advise me on how to remove the steering wheel from my mk6 escort van/
Old Apr 20, 2010 | 11:48 PM
rscos2004's Avatar
rscos2004
Default steering wheel removal
Hi you normally turn the ignition two position 1 or 2 and take center nut off and rock it back and too and it will come off cheers.
Old Apr 21, 2010 | 11:15 AM
Lowson's Avatar
Lowson
You have to turn the steering wheel a quarter of a turn each way from straight to get access to the two nuts on the back of the steering wheel that hold the air bag on. Think it's an 8mm socket required IIRC. Once the air bag is off, undo the big nut, make sure the steering lock is off and just give the wheel a good tug and it'll come off.
Old Apr 21, 2010 | 12:21 PM
martysmartie's Avatar
martysmartie
To add when working with airbags it's good idea to disconnect battery as so with most things, encase you accidentally deploy the airbag.
Martin
Old Apr 21, 2010 | 03:29 PM
cossiejay's Avatar
cossiejay
disconnect the battary,undo the 2 torx bolts that hold the airbag on these dont come all the way out,unplug the airbag and be careful with it ,point wheels straight and mark with a marker pen where the wheel is on the shaft ,undo centre nut turn ignition key to remove the steering lock,and wobble wheel until it comes off job done
Old Apr 23, 2010 | 09:29 PM
polly's Avatar
polly
thanks for all the advice folks
Old Apr 23, 2010 | 09:40 PM
James @ M Developments.'s Avatar
leave the nut on loose, otherwise when you pull proper hard on the wheel it will come off and break your nose...ive seen it done lol
JoeyBoyden
Jan 4, 2024 02:36 PM
YODI
Aug 30, 2015 01:12 PM
RockinRein
Aug 19, 2015 07:08 PM
Roosie
Aug 19, 2015 11:52 AM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
