info needed on 195 ofac superchip
anybody know what the boost limit / cut off is on a 195 superchip (ofac)
and the settings for the fuel pressure and emissions settings are ?
need to know so i can set it up so i can get the car to the rolling road
The Ofac map sensor can only read 1 Bar of boost , so would say until you get it rollered and make sure that the engine is working correctly set it at 13.5-14psi , fuel pressure should be set at std and set the co to 3% and see how it goes .
The OFAC ECU has a 2.5 bar MAP sensor and can register 1.5 bar of boost. There are some internal restrictions within the ECU that mean the ECU can't scale past about one bar of boost. However MSD have overcome this limitation with some clever programming.
I ditched my crappy superchip and went for a MSD one - would definitely do it again as it is so much more economical and did over 200BHP when rolling roaded.
Jack and the Beanstalk
09-08-2015 07:03 PM
