Zetec Burning Oil?
Old Apr 19, 2010 | 05:23 PM
JamesyRS's Avatar
JamesyRS
Default Zetec Burning Oil?
Hey guys,
Right give you the low down. The car never once burnt oil when I got car, got it on road still no oil burning. I serviced car with new plugs etc oil filter and oil change. Since then its began burning oil? Its clear on start up and no smoke atal when booting it or driving which just dont make sense. I used castrol 5w/30. possibly wrong oil to use? it is cammed which I dont know if makes a diff? racing oil or whatever? any help would be appreciated guys thanks
Old Apr 20, 2010 | 09:16 PM
forevaford's Avatar
forevaford
is it a 1.6? iv found these to burn oil.
Old Apr 20, 2010 | 09:29 PM
JamesyRS's Avatar
JamesyRS
na mate its 1.8 gti engine
Old Apr 20, 2010 | 09:38 PM
pani_k's Avatar
pani_k
PassionFORD Member
Checked for any leaks in obvious places like sump nut and oil filter as these may not be done up tight or sealing properly? Alternatively is the sump leaking or anywhere else visible? Rocker cover gasket?
Old Apr 21, 2010 | 06:29 PM
forevaford's Avatar
forevaford
try 10w40 pehapps.
Old Apr 21, 2010 | 06:33 PM
pani_k's Avatar
pani_k
PassionFORD Member
Originally Posted by forevaford
try 10w40 pehapps.
This will not solve your problem and is NOT the recommended oil by Ford and you will suffer sticky valves.
Old Apr 23, 2010 | 03:09 PM
JamesyRS's Avatar
JamesyRS
hi mate no oil leaks anywhere, in previous history my zetecs never seemed to like the castrol 5w30 so thought it may ahve been that as no leaks no smoke everything seems fine
TPM961
Jan 15, 2018 10:50 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Bransby
Sep 21, 2015 05:29 PM
Chopshop85
Sep 18, 2015 06:13 AM
BRAM
Sep 8, 2015 07:11 AM
