Boost Control
Old Apr 17, 2010 | 06:15 PM
Olivera's Avatar
Olivera
Default Boost Control
My 2wd Sapphire currently has the actuator connected directly to the compressor housing. There is no amal or bleed valve in the current setup.
Am I right in saying its recommended to refit an amal valve to allow the ECU to have some control over boost pressure? Where can I buy one and how should it be connected?
Old Apr 17, 2010 | 06:30 PM
martysmartie's Avatar
martysmartie
Correct, at the moment you have no boost control at all, you can only run what the actuator will allow, put back the Amal and you have electronic boost control and will run higher boost to what the chip has been written for. Paul at NYRS could sort you out or the bay may have one.
Martin
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
