starting problems HELP ASAP
Old Apr 16, 2010 | 09:39 PM
dlf3yburt's Avatar
dlf3yburt
Default starting problems HELP ASAP
Hi all
I have a m8s car at mine when we start the car we get a high pitch squealing noise from the starter motor area. I have changed the starter and have the same problem on different starters. When the car is running the there is no noise only when trying to start the car it makes the noise?
Any help would be great as need it for sunday
Many thanks
DLF3YBurt
Old Apr 16, 2010 | 10:36 PM
rscos2004's Avatar
rscos2004
Default cosworth running problems.
Originally Posted by dlf3yburt
Hi all
Many thanks
DLF3YBurt
Hi it may sound daft are fan belts tight or flywheel coming loose.
Old Apr 16, 2010 | 10:40 PM
botters's Avatar
botters
competant bodger
what car is it? does it have a dual mass flywheel?
Old Apr 17, 2010 | 07:57 AM
whittyscossy's Avatar
whittyscossy
Belts are tight.
only does it when it trys and starts ??
its a 2wd saph 89.
Old Apr 17, 2010 | 08:06 AM
MannheimAlex's Avatar
MannheimAlex
If it is only when the starter kicks in, maybe the teeth of the starter/flywheel are worn.
Old Apr 17, 2010 | 12:27 PM
Maybe it is a inlet leak, and that once started the noise of the engine is masking the noise ?.
Normal noise like this would be the nose cone bush packing up/seizing, but not on different starters.
Old Apr 19, 2010 | 08:26 AM
whittyscossy
sorted now many thanks for answers.
Not belts was starter. There was a difference of 1mm on starter.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
muffster
13
Sep 3, 2015 09:40 PM
nick8saff
Aug 16, 2015 05:35 PM
Sjieter
Aug 5, 2015 09:47 PM
