1.6tdci non start
Old Apr 15, 2010 | 05:30 PM
Fordfocused's Avatar
Fordfocused
Default 1.6tdci non start
Hi can anyone help?
I have an 06 ford focus 1.6tdci 90ps which turns over but will not start.
I bought it with a seized engine due to a wack to the sump which damaged the oil pick up. I then sourced a secondhand engine as a replacement. It was a complete engine with diesel pump and injectors.
Once I completed the engine swap found that the engine would not start. I was then told that the injectors were coded so I removed the injectors from the original engine and then the replacement engine except for one which seems to be stuck, it is the injector nearest the timing belt (cylinder 4?).
After days of trying to remove the last injector without success, ( I tried soaking it in wd40, coke + cilit bang, levering it and pulling it with a large slide hammer), I decided to change the injectors that I could making sure that they go back to the correct cylinders to then start the car on 3 cylinders and hope that the 4th will free itself. The car will still not start, I have checked all of the fuses and before I replaced the injectors I checked for fault codes using a reader that only does engine codes.
Any suggestions? Sorry for the essay but the more info I give the more chance of help!
Thanks, Dan.
Old Apr 15, 2010 | 05:50 PM
Fordfocused
I forgot to mention that there doesn't seem to be any fuel coming through and the fuel filter is full.
Old Apr 15, 2010 | 06:23 PM
RS500/364's Avatar
RS500/364
Sure has not got a fuel cut off switch !
Old Apr 15, 2010 | 06:26 PM
ste1806's Avatar
ste1806
the only thing i can think of is when i serviced mine, it wouldn't start even with the fuel filter seeminly full, i then put a vacuum pump on the return to the tank from the fuel rail and pumped a bit and it then started. So your problem might be an air lock in the fuel rail. hope this is some help
Old Apr 15, 2010 | 09:36 PM
Fordfocused
I did that before when it had the wrong injectors, but I suppose I have disturbed the fuel lines again. Thanks for the suggestion, I also plan to put a diagnostic computer on it too.
Old Apr 15, 2010 | 09:42 PM
cos400's Avatar
cos400
wot about the pump that code 2
Old Apr 16, 2010 | 07:12 AM
Fordfocused
That has been mentioned before but there are no wires or electrics on it. I spoke to a diesel specialist and told them my dilema, they said that the injectors were coded but did not mention the pump.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
