Running in cams
Old Apr 15, 2010 | 01:19 PM
ozmk1cos's Avatar
ozmk1cos
Default Running in cams
Whats the best method of running in used cams on new lifters?
Old Apr 17, 2010 | 02:08 PM
Follow the instructions given, which are normally don't let the revs drop below about 2000rpm for first 20 mins or so.
Old Apr 17, 2010 | 02:17 PM
ozmk1cos's Avatar
ozmk1cos
Thanks for that. Similar to a pinto then, is this a standard for all cams?
Old Apr 17, 2010 | 03:29 PM
MarkN's Avatar
MarkN
Depends on the engine. I'd never bother fitting new lifters to an old CVH cam for example - the worn cam lobes would wreck the new lifters in minutes and you'd be back where you started.
Where I've fitted them as a it I've always done as Tabetha suggests above. Use the lube supplied and then sustained RPM between 2500 and 3000 for about 20 minutues, and never let it drop to idle until the 20 minutes is up.
dombanks
Sep 21, 2015 08:38 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
Chopshop85
Sep 12, 2015 06:42 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
rog
Sep 4, 2015 07:24 AM
