ford ka battery lt on
Old Apr 13, 2010 | 08:14 AM
u614670's Avatar
u614670
Default ford ka battery lt on
battery lt came on, orange red wire on 3-pin plug to alternator corroded so bought new loom from ford and spliced it in,batt lt still on,replaced alternator, light still on-battery seems to be charging ok-any ideas as to why light staying on.Also where does wiring loom from alternator go to.
Old Apr 13, 2010 | 11:16 AM
I thought these might have been ecu controlled charging circuits but doesn't sound it from your description.
Anyway the thin wire leading to the dash charge lights only needs a earth to illuminate the light, with ignition on, so check the wire isn't earthing out on something, the earth would normally come from the alternator, which changes to live upon charging hence putting the light out, so needs sorting asap, look for a worn through wire etc between alt and dash light.
Old Apr 13, 2010 | 10:41 PM
16imarty's Avatar
16imarty
remove fuze box behind ther is a fuze on its own check that
Old Apr 14, 2010 | 09:08 AM
u614670's Avatar
u614670
thanks for your replies,girlfriend just telephoned, battery dead after 20ml journey so obviously not charging,think wiring is probably the problem but will also check fuse behind fusebox?
Old Apr 14, 2010 | 07:34 PM
cabriolet's Avatar
cabriolet
the wire rubs through up on the bulkhead fella it comes from the alternator under the radiator down the passenger side inner wing across the bulkhead in through the drivers side check also the terminal on the big power lead from the alternator they go green and rot off u wont see it til u undo it
Old Apr 15, 2010 | 01:18 PM
martysmartie's Avatar
martysmartie
These DO use ECU controlled "Smart-charge" that is what the 3 pin plug is for. If the 3 pin plug was not replaced on the alternator check for a broken wire on it.
Martin
FordJonah
Aug 22, 2015 08:31 PM
borboyous
Aug 22, 2015 11:17 AM
cameron2
Aug 19, 2015 09:38 AM
track.focus'd
Aug 12, 2015 05:53 PM
