1990 mk4 escort EFI
Old Apr 11, 2010 | 03:14 PM
pierce's Avatar
pierce
Default 1990 mk4 escort EFI
need some help it wont rev up, sound like its not getting enough fuel but I have changed the map sensor, the injectors, the TPS, the air temp sensor, the coolant temp sensor, I have tried everything I can think of do you think it could be the ECU
Old Apr 11, 2010 | 03:18 PM
studabear's Avatar
studabear
fuel filter blockage perhaps
Old Apr 11, 2010 | 04:37 PM
pierce's Avatar
pierce
its not very old and I have good fuel pressure in the rail
Old Apr 11, 2010 | 04:56 PM
studabear's Avatar
studabear
co pot? I remember reading something about these on anotherforum, been looking for article but no joy
Old Apr 11, 2010 | 06:46 PM
pierce's Avatar
pierce
do you know if i can test it
Old Apr 11, 2010 | 08:48 PM
MarkN's Avatar
MarkN
Very unlikely to be the CO pot. You can test it by unplugging it altogether and see if it makes any difference.
What do you mean when you say it won't rev. Will it not go past a certain RPM, or is it really slow to pick up?
Old Apr 11, 2010 | 09:52 PM
Toe Knee's Avatar
Toe Knee
have u checked the fuel return pipe to see how much if any is returning to the pump?!
Sounds similar to my xr2i problem and that was down to the seals on the pump damper as 1 had split, tried loads of things till i realised it was that and never thought to check how much fuel was returning, which in my case was none due to poor pressure!
Old Apr 13, 2010 | 08:28 PM
pierce's Avatar
pierce
I will check the return. when you press the accelerator it dies. this doesn't have a pump damper
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
bigryrs
Sep 7, 2015 06:45 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
cossirob
Sep 3, 2015 09:17 PM
Bighandsuk
Sep 2, 2015 05:23 PM
