how do i read fault codes
Old Apr 11, 2010 | 02:06 PM
left hooker's Avatar
left hooker
Default how do i read fault codes
hi i have a 2wd left hooker saff and want to see if i have any fault codes
how do i go about checking for codes
Old Apr 12, 2010 | 06:08 PM
If it is a 2wd sapph cos they don't support meaningful fault codes, do you have a particular problem ?
Old Apr 12, 2010 | 06:13 PM
oldford's Avatar
oldford
You would need a so-called Led-tester or Star-tester from Ford to read the codes.
There are 9 codes available. So very basic.
Old Apr 12, 2010 | 06:24 PM
martysmartie's Avatar
martysmartie
What he ^^ said, although you can easily make your own LED reader, don't use myself as usually easy enough to figure out what's wrong, if EMS related at all, fault codes just make it easy.
Martin
Old Apr 12, 2010 | 06:27 PM
left hooker
its a 2wd saff cozzie left hooker had the turbo go so replaced the turbo finaly put it on the road last weekend and tryed setting the boost up (1.5 bar) and only making 0.7 bar and when i get over 4000 rpm i get a miss ?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Iain Mac
Sep 30, 2015 09:39 PM
20/20 vision
Sep 29, 2015 11:27 AM
