engine compartment to passenger bay wiring?
Old Apr 2, 2010 | 10:54 PM
digiam.j's Avatar
digiam.j
Default engine compartment to passenger bay wiring?
What would be the best way to send a wire from the engine compartment to the passenger bay? 2002 mustang v6. i'm just wiring 2 12"s in the back and i got it all workin i just need to run the power wire through to the battery.
couldn't find a post for this on the thread. maybe i'm dumb.
Old Apr 3, 2010 | 06:59 PM
Just use some adequate sized cable, through a grommet in the bulkhead is the normal way, not forgetting to fuse it nearest the battery with correct rating fuse.
To work out current draw if needed use the V/I x R formula, otherwise most likley in the handbook for the amps ?
Welcome to pf btw.
Old Apr 3, 2010 | 07:17 PM
saph_Al's Avatar
saph_Al
the V/I x R formula = Ohm's law
Heres a link to a calculator if your not to familier with it
http://www.csgnetwork.com/ohmslaw.html
Cheers Ally
j.hammond1
30
Oct 31, 2021 05:28 PM
muz
Aug 16, 2015 12:57 PM
track.focus'd
Aug 12, 2015 05:53 PM
yawiejon
15
Aug 9, 2015 06:36 PM
