fiesta rs turbo crank posistion sensor
Old 11-01-2005 | 09:42 PM
dean erst's Avatar
dean erst
Default fiesta rs turbo crank posistion sensor
I have an s2 running cossie managment i have just got a new bottom end with an efi flywheel and the cut out on the block can i just use the fiesta rs turbo crank posistion sensor on the fly wheel instead of the tdc and will it work in the same way or do i still need to use the tdc sensor and have the fly wheel abapted if any one can give me some advice this will help me a grate deal thanks
Old 13-01-2005 | 08:18 PM
dean erst's Avatar
dean erst
can anyone help please!!!!!!!
Old 13-01-2005 | 09:01 PM
sammy's Avatar
sammy
hi, ive got cossie management on my 2ltr zvh frst & gonna do my tdc on the flywheel next time i change the g/box (never to long!), cant remember for sure which crank sensor to use (think its the zetec 1 if its a zetec bottom end) i have seen it mentioned on www.fiestaturbo.com or a link from there, poss in guides&faq. as for the flywheel its easy look on www.zetec-turbo.co.uk under management, good luck mate
j.hammond1
30
31-10-2021 06:28 PM
paceo
03-02-2016 11:31 AM
carlo
24
05-10-2015 09:20 PM
Zoggon
10-08-2015 11:39 AM
knight19770
04-08-2015 01:36 PM
Quick Reply: fiesta rs turbo crank posistion sensor
