zvh rs turbo wont start
hi guys hows things, i wanted to pick your brains a bit ,just got my new 2.0 zvh fitted into my car but cant seem to get it running everything is as it was before removal, fuel settings etc ive not touched anything like that ,basically the car will start after about 25-30secs of turning over but only keep going on full throttle which allows it to tick over at approx 5-600 rpm (very lumpy)it seems to be getting a good spark and ive double checked the hoses are fitted correctly from inlet manifold/charge carrier right through to the metering unit incase it was leaking air also flushed the old fuel out an put new fuel in ive cracked each nut of the injector lines on top of the metering head and they all seem to be geting fuel ok ,i know its difficult to diagnose a car without it being in front of you but any advice would be greatly appreciated,cheers matty
CabrioTurbo
01-08-2015 11:04 AM
