injectors and cams
Old Mar 21, 2010 | 01:31 PM
davecosworth's Avatar
davecosworth
IM BACK
Default injectors and cams
what injectors to replace greys on a cosworth running t38 7:5:1 com l8 closed loop also what cams as not sure if it they have been changed
Old Mar 21, 2010 | 05:38 PM
Have you run out of injector duration then ?
If not why change them, if ok they are a ace injector, and will give ace economy power and emissions, IF mapped correctly, you could also lose the unecessary closed loop then.
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
