speedo drive pinion
Old Mar 20, 2010 | 12:26 PM
alirst's Avatar
alirst
Default speedo drive pinion
hi guys, got a bit of a question
the speedo drive pinion on my frst needs replacing.
a friend of my dad's fancies himself as a bit of a cvh expert and recons that if the speedo pinion needs replacing the dif bearings will also be warn so repacing the pinion will only fix it temorarily.
is this correct?
Old Mar 20, 2010 | 04:13 PM
Most likely, when the diff bearings wear the movement wears the speedo drive pinion, they don't normally wear as no great load on them just a cable.
Only way to see is to try a new one.
Old Mar 21, 2010 | 01:08 PM
JesseT's Avatar
JesseT
You can take the speedo drive pinion out and see if the shape is like )( instead of ||. So, if it's worn in the middle, the diff bearings are on their last legs.
Brickhouse
14
Oct 3, 2015 07:28 PM
stevecfrst1
Sep 30, 2015 05:18 AM
20/20 vision
Sep 29, 2015 11:27 AM
SMILER258
Sep 28, 2015 09:04 AM
