zetec question
Old Mar 17, 2010 | 10:30 PM
alexno1dj's Avatar
alexno1dj
Default zetec question
on a mk6 escort is a swap from 1.6 to 1.8 literally a direct swap?
i know the 2 litre needs a few parts from the 1.8
Also are the mounts different on a blacktop?
answers much appreciated. cheers
Old Mar 17, 2010 | 10:43 PM
alexno1dj's Avatar
alexno1dj
any one?
Old Mar 18, 2010 | 07:46 PM
alexno1dj's Avatar
alexno1dj
no one got anything to add?
Old Mar 18, 2010 | 08:01 PM
rs_turbo_tony's Avatar
rs_turbo_tony
zetec 1.8 straight swop plus ecu . 2ltr swop sump, oil pick up pipe ,and water pump .black top shud go in with mounts from your engine . you can use 2 ltr 130 hp inlet cam and inlet ,manifold plus ecu and maf and map sensor hope this helps
Old Mar 18, 2010 | 08:03 PM
alexno1dj's Avatar
alexno1dj
yeah thats great cheers
Old Mar 18, 2010 | 08:15 PM
mercgrey's Avatar
mercgrey
doubt you will get blacktop on silvertop mount unles you weld a plate to it as the stud patern is diffrent iirc it nomally mounts next to the cams! not hard to weld a focus mount in there tho if you wanted to!
Neil Clark
21
Oct 1, 2015 07:02 PM
Fiddy
21
Sep 29, 2015 06:10 PM
focuspower
Sep 20, 2015 03:51 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
