help with exhaust smoking problem
Old Mar 14, 2010 | 06:50 PM
robgee32's Avatar
robgee32
Default help with exhaust smoking problem
can any one please help
i own a escort mk6 with a zetec turbo engine and when i start the car it runs fine after a short drive and car gets to running temp there is white smoke from exhaust and starts to idle a little ruff
its not loosing water or oil so what could be causing it
thanks
Old Mar 14, 2010 | 09:31 PM
steve4i's Avatar
steve4i
white smoke's normally sign's of water burning hence steam
do a pressure test on the water system see if it's only getting into a pot when it's warm incase the heads warped and its only letting it in under pressure
Old Mar 15, 2010 | 06:30 PM
xtrmjks's Avatar
xtrmjks
My zetec turbo did the same when oil seals went on the turbo...
remove downpipe and check for oil..
JK12
33
Apr 26, 2021 12:09 PM
Marino
Sep 12, 2015 11:10 AM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
turbowag
Sep 3, 2015 08:07 AM
