Spark Plug question
Old Mar 13, 2010 | 01:10 PM
AstoN_B's Avatar
AstoN_B
An eye for detail...
Default Spark Plug question
For a friend.
His rally car keeps burning spark plugs out, sometimes two sets in a days rallying sometimes not at all. It the porcelain bit that burns not the spark tip.
He's been using NGK TR5a/10 as thats what parts place said would be best.
Car is a Mk3 fiesta with 1.6engine but 2.0 head apparently.
What plugs would be better to try? I thought some with higher temp range unless theres too much power coming to plug which is burning it out?
Never heard of that though
Old Mar 13, 2010 | 03:57 PM
What precisely do you mean by burn.
If it was getting hot enough to melt the porcelain you'd have no engine well before that, as it would have melted first.
Porcelain is normally made from Kaolin, which is aluminum hydrosilicate, this is fused with white quartz, well specifically feldspar, at a temperature of 1300-1400 C.
Even soft procelain needs 1100C to melt.
It can be pitting or something else though, really need to see a plug.
Old Mar 14, 2010 | 03:56 PM
AstoN_B's Avatar
AstoN_B
Only problems I've heard of are where the porcelain comes loose from the threaded body.
It appears to be orangey brown where the lead plugs on. That's the description I got. I'll try and get a picture in next couple days cause it's at his lockup unles he's got an old set.
Any ideas so far?
Old Mar 14, 2010 | 05:15 PM
The orange colour is okay, it's called corona discharge, you get it where high voltage and electric conductive liquids are in close proximity, usually oil fmes is enough to do it, they get attracted to the porcelain and cause the staining, if it gets like streaky lightning looking though this is discharge through the body gap between porcelain and metal, not good need throwing away.
As to why they become loose in the body is a mystery, only ever had that once in 25+ years.
Old Mar 16, 2010 | 09:08 AM
AstoN_B's Avatar
AstoN_B
I'll have a proper look when it's next out. Hopefully somethng of nothing. Didn't ask whether there was a misfire too. Probably is just some oil vapour, maybe something in the lead plug.
If I get chance I'll get a photo.
chowfornow
14
Jan 5, 2019 09:01 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
pabloXR
Sep 21, 2015 12:42 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
