fiesta mk4 zetec reverse sensor location?
Old Mar 9, 2010 | 10:37 PM
ikarma70's Avatar
ikarma70
Default fiesta mk4 zetec reverse sensor location?
Hi all,long time no post!
Can anyone tell me where the reverse sensor/switch is on a 1.25 zetec motor pls(photo's would be helpful too for anyone else for future reference)?
My reverse light has packed up and I'm sure its the sensor,its not the bulb as my rear lights work ok and it has been an intermittant problem as when the reverse is engaged,the light goes on but let go off the gearstick,it goes out.
thanks in advance.
Andy
Old Mar 10, 2010 | 09:21 AM
ikarma70's Avatar
ikarma70
anyone?
Old Mar 10, 2010 | 12:34 PM
Certainly does sound just like it needs adjusting.
I can't help with where it is, other than to say have a look around the gearbox, you will see a 2 wire connector on it, the only electrical connector going into the gearbox, so can't be mistaken, adjusting usually screw in or out a bit further.
Old Mar 11, 2010 | 07:27 PM
waynefrst235's Avatar
waynefrst235
The switch is on the gearbox, fairly certain its on the front. Simple to get in about 2
Old Mar 12, 2010 | 05:44 PM
ikarma70's Avatar
ikarma70
thanks ladies and gents but i think the location of this 2 wire switch has been sorted...my gearbox doesnt use that 2 wire switch,the garage(my mate owns it) said it uses the sensor unit that came on the updated gearboxes that did away with the 2 wire switch.
JoeyBoyden
Jan 4, 2024 02:36 PM
23
Sep 12, 2015 12:56 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
turbobill
Aug 1, 2015 08:55 PM
