why does this happen????
Old Mar 9, 2010 | 12:00 AM
alexno1dj's Avatar
alexno1dj
Default why does this happen????
Hi,
Ive just been out for a spirited drive and i cant understand why when coming up to a junction or lights, when i put clutch in the revs drop down to 400 rpm then start bouncing from 400 to 1200 for about 20 secs as tho the car is hunting revs.
Any ideas please?
cheers
Old Mar 9, 2010 | 12:09 AM
alexno1dj's Avatar
alexno1dj
is this the icv?
Old Mar 9, 2010 | 08:53 AM
phil_focus's Avatar
phil_focus
could be vss (vehicle speed sensor) too.
Old Mar 9, 2010 | 12:08 PM
What car ?
Old Mar 9, 2010 | 12:12 PM
martysmartie's Avatar
martysmartie
No the ISCV is shown to be working by the fact it's hunting. It's being told to do this most likely the VSS at fault also check clutch pedal switch though don't think it will be this as it just tells ECU when clutch is depressed I think which raises revs so as to achieve a smoother change but has been known to cause problems.
Martin
Old Mar 9, 2010 | 07:44 PM
alexno1dj's Avatar
alexno1dj
Originally Posted by tabetha
What car ?
its a mk6 escort zetec, pretty annoying. Where is the VSS located?
Old Mar 10, 2010 | 12:33 PM
martysmartie
On the gearbox.
Martin
Becka674
11
Oct 8, 2015 03:11 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
