fiesta mk6 facelift heated screen
Old Mar 8, 2010 | 01:38 PM
fiesta56's Avatar
fiesta56
Exclamation fiesta mk6 facelift heated screen
right i will start off by saying i have a 5 door fiesta stye with non front heated screen, I want to put a front heated screen in becuse i have cracked my screen right i have found that i have the plugs both sides of my pillows in my car dnt think u have the relay and switch tho now my Q is if i get the relay switch and the screen can i plug it all in ect and it will work or am i wasteing my time and money and can some one advise me of a part number for the relay as ford cant find it on there computers nd help that be great
Old Mar 8, 2010 | 09:15 PM
frst_lad's Avatar
frst_lad
well your lucky that you got the plugs, if thats the case, wack the earth in, get a relay in (scrap yard or parts department)
then get a switch also and a fuse and you should be off, with the screen that is
Old Mar 8, 2010 | 09:20 PM
fiesta56's Avatar
fiesta56
i have tryed to get a relay but no luck also were on eath do you plug it in cant find it
Old Mar 8, 2010 | 09:28 PM
furqall's Avatar
furqall
when you have the screen fitted it will have have 4 terminals attached , 2 of them will plug into the loom that you have found behind the a pillar covers ,the top 2 are the earths and they bolt to the a pillar behind the a pillar covers
Old Mar 8, 2010 | 09:43 PM
fiesta56's Avatar
fiesta56
so the screen will have 2 wires both sides of the windscreen and all i do is plug them into eather side of the plugs on the car and then get the relay plug that into the fuse box and swop over the switch
Old Mar 9, 2010 | 12:31 PM
martysmartie's Avatar
martysmartie
The screen will plug in as you say you have the plugs so you need a relay and switch as said best bet is to go scrappy
Martin
Old Mar 9, 2010 | 12:37 PM
fiesta56's Avatar
fiesta56
i have lookeed in my fuse box and as far as i can see no relay are missing unless some on blank ones just put in to fill the gaps
Old Mar 9, 2010 | 05:34 PM
martysmartie
In that case you may just need a screen + switch.
Martin
Old Sep 12, 2011 | 07:12 AM
M K's Avatar
M K
Has anyone worked out yet if the relay needs adding? Or is it just a case if heated screen and new dash switch?
I'm looking at buy a mk6 fiesta tonight but it does not have heated screen and coming to winter I want 1
Thanks
Marc
Old Sep 12, 2011 | 08:49 AM
daviddunlop83's Avatar
daviddunlop83
When i fitted a heated screen to my focus ST170 with teh switch and relay and fuses it also needed an additional engine run relay and also turned on with the computer IIRC by ford
Old Sep 12, 2011 | 12:20 PM
martysmartie
Depends, you can always wire with a timing relay etc, this is merely a simple circuit and is what the setup was in older Fords.
It shouldn't be anything complicated, far as I am aware the only interaction of modern day setups with the ECU, is that it turns the screen off, after a pre determined period of time, in the same way as the timer relay did.
Martin
Old Jan 22, 2013 | 09:13 PM
focus 4x4's Avatar
focus 4x4
Does anyone have any info on fitting a heated front screen to a mk7 fiesta?
So far ive fitted the heated screen and conneted the earths to the A pillars.
And sourced a new heater control pannel which has the heated screen switch.
I seem to be missing the + feed wires to the screen .....
Old Jan 23, 2013 | 12:34 PM
martysmartie
These will go via a relay, with the power connecting to the battery, it's CRUCIAL you choose the correct size gauge wiring though, due to the draw of the screen!
Martin
Old Jan 23, 2013 | 04:31 PM
daviddunlop83
When i did it on my Focus ST170 ford also had to activate it in the GEM module.
Also there was an engine run relay needed put in.
All the wiring was there for the screen, i just had to change the buttons inside the car and they added the relay and activated it.
rex647
Mar 6, 2022 06:20 AM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
cossie09
Sep 10, 2015 06:56 PM
